Exterior- TSX retro's (done by Brian)
- Mugen license plate bolts
- VIS carbonfiber trunk (removed)
- amber turn signals (tinted)
- Aerocatch locking hood pins
- PWJDM Aerocatch retaining ring
- Seibon carbonfiber hood
- Mugen GP wheels
- Mugen wheel locks
- LED tail lights (not installed)
- Azect eyelids (not installed)
Suspension / Brakes- Tein Super Street Coilovers w/ pillow mounts
- Spoon Sports rear strut tower bar
- Megan adjustable toe arms
- Innovative traction bar
- Custom rear endlinks
- Energy Suspension bushings all around
- SPC adjustable rear upper balljoints
- Powerslot cryo slotted rotors (front and rear)
- Hawk HPS pads (front and rear)
- Stop-tech brake lines
Motor / Bay- Vibrant 3" custom CAI
- Vibrant intake couplings
- (20) NRG Titanium fender washers
- Clutchmasters fx300 clutch
- Fidanza 8lb flywheel
- (2) 12" MIZU cooling fans
- custom coolant catch can
- Rosko IM gasket
- Rosko TB gasket
- (2) Hella Horns
- K&N 3" intake filter
- custom cooling plate
- Electric Hydraulic Power Steering conversion
- Custom Innovative 75a motor mounts (Modified drivers mount, one off bolt sleeves)
- Custom clutch line - clutch damper bypass
- S2000 clutch master cylinder
- Checkered sports S2000 mc spacer
- SMSP 3" exhaust piping/Greddy Evo2 muffler/Vibrant 18" long 3" inlet/outlet 4" OD resonator
- SMSP header + custom catalytic converter (2.5" inlet 3" outlet, 200 cel)
- AEM fuel rail
- Tomei fuel pressure regulator
- Walbro 255 fuel pump
- RC 550 saturated injectors
- Marshall fuel pressure gauge
- ARP header studs
- Extended intake manifold studs w/ nylon washers
- Crower adjustable cam gears
- Mizu radiator
- Custom A/C lines
- Mishimoto baffled catch can
- Driveshaft shop stage 2.9 axles
- Relocated ABS unit w/ custom lines
- Kazinspeed manual tensioner/Gates racing timing belt
- Euro R single row crank pulley
- PCI header skidplate
- Jackson Racing Super Charger w/ ARP hardware
- Motorvations 9psi pulley (awaiting install)
- KS balance shaft delete
Interior / Audio / Electronics- Pioneer speakers all around
- P-SPEC adjustable short shifter
- P-SPEC shift knob
- Integra Spoon convex mirror
- Glowshift oil pressure gauge
- Greddy Emanage Ultimate
- Boomslang harness
- PLX m300 wideband
- AEM boost gauge
- 6th gen Accord radio pocket
- LED slimline 3rd brake light
- Black dash mat
Honda Access- JDM window visors
- USDM lip kit (complete)
- JDM digital climate control
- Locking cup holder
- JDM fog lights
- Gunmetal grill
- ITR chrome oil cap
- Rear ash tray (not installed)
- Bug deflector (not installed)
- Engine block heater (not installed)
OEM maintenance/ new parts - these are either installed, or sitting in a large box...
- both rear calipers - honda remanufactured
- valve cover/ spark plug gaskets
- oil pump
- balance shaft seals
- cam gear seals
- cam plug seal
- vtec solenoid seals
- cap/rotor
- spark plugs/ wires
- intake manifold plenum gasket
- all transmission seals
- rear main seal
- front crank seal
- rear wheel bearings
- water pump
- L/R fender liners
- L/R hood seals
- L/R window outer seals
- L/R window outer moldings
- floor mats
- drivers seat base
- roof trim
- rear window seal
- tail light seals
- L/R window motors
- L/R door seals
- L/R front wheel bearings
- all 4 lower balljoints
- L/R exterior door handles
- L/R interior door handles
- L/R outer tie rods
- front window seal
- sunroof seal
- L/R quarter windows
- shifter cables
- slave cylinder
- brake mc seal
- coolant temp sensor
- thermostat
- knock sensor
- ignition switch
- grill w/ emblem
- front bumper
- L/R turnsignals
- wiper cowl
- L/R inner/outer tie rods
- turn signal switch
- all undercarriage 10mm bolts
- L/R headlights
Things left untouched with over 150k miles;
- steering rack
- valve stem seals
- piston rings
Future;
- re clear hood/trunk
- re spray entire car NBP
- motor rebuild
- re spray bay (again)
- ap1 steering wheel
- new fenders
- JRSC rebuild
Support your fellow enthusiasts!
www.jtccustoms.comwww.extremeprelude.comwww.explicitspeedperformance.netwww.roskoracing.comOther sites i've purchased from;
www.icbmotorsports.comwww.inlinefour.comwww.andysautosport.comwww.checkeredsports.comwww.sms-products.comwww.tirerack.comwww.sparkplugs.comwww.innovativemounts.comwww.corbeau.comCheck out my write-ups!
5th gen Wire tuck -
http://preludecentral.com/index.php/topic,770.0.htmlReduce that wink mirror shake -
http://preludecentral.com/index.php/topic,808.0.htmlNo back seat? Plug the holes! -
http://preludecentral.com/index.php/topic,771.0.htmlOil catch can to coolant overflow tank conversion -
http://preludecentral.com/index.php/topic,773.0.html
